Upgrading From a Legacy Model to a 4th Generation Tablo
What To Consider
If you have a legacy Tablo DVR and want to make the switch to 4th Generation, here's a detailed article on what you need to consider.
setting up 4th Generation Tablo
In short, the major differences between our 4th Gen Tablo models and legacy Tablo devices are:
  • Many of the underlying technologies used by legacy Tablo apps and services are becoming obsolete and are no longer maintainable. This is why we discontinued support for all legacy Tablo apps on September 1st, 2026. The 4th Generation apps, on the other hand, are fully available and supported.
    If you own a legacy network-connected Tablo model (Tablo DUAL LITE, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB and the original 1 and 2 Tuner Tablo DVRs), your old apps will remain accessible to you but won’t be maintained or updated and are not available to download from app stores.
  • 4th Generation Tablo apps require no TV Guide Data Service Subscription. You get 14 days of rolling TV Guide data for free.
  • 4th Generation Tablo apps not only display the over-the-air channels you are used to but also grant you access to 100+ free streaming channels. Keep your old antenna, it will work with your 4th Generation Tablo as well.
  • You need a compatible iOS or Android mobile device to set up a 4th Generation Tablo.
  • 4th Generation Tablo DVRs can pick up the handful of ATSC 1.0 channels broadcast in MPEG-4, whereas legacy models cannot. This means, depending on your location, your 4th Gen Tablo may pick up even more channels.
  • All 4th Generation Tablo DVRs come with 50+ hours of internal storage. You can also connect an external hard drive for even more storage. *
  • All 4th Generation Tablo DVRs come with whole-home streaming to compatible devices in your home. You will need a Wi-Fi network**
  • 4th Generation Tablo apps do not support Tablo Connect for out-of-home streaming or Automatic Commercial Skip. You can, however, still fast-forward and rewind content.
    The Automatic Commercial Skip feature will be discontinued for all grandfathered users on December 31, 2026.
  • 4th Generation Tablo DVRs are not available in Canada.
* Some, not all, legacy models also have internal storage. Specifically: Tablo DUAL 64GB OTA DVR, Tablo DUAL 128GB OTA DVR and Tablo QUAD 1TB OTA DVR.
** Network-Connected legacy models also offer whole-home streaming to compatible devices, but TV-connected models are very limited in this respect.
The Legacy Transition Program
Legacy network-connected Tablo models (Tablo DUAL LITE, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB and the original 1 and 2 Tuner Tablo DVRs) can take advantage of the Legacy Transition Program. This allows them to install 4th Generation Apps.
Benefits of transitioning to 4th Generation Tablo apps include:
  • A fully revamped and easy-to-use interface
  • Subscription-free TV guide data and DVR features, including the ability to set series recordings
  • Access to 60+ free streaming channels within the 4th Generation Tablo interface (US residents only)
For additional details on the Legacy Transition, see:
How To Replace Your Legacy Model with a 4th Gen
After upgrading to a 4th Generation Tablo, here's how to make the switch:
Cancel Your TV Guide Data and/or Premium Service Subscriptions
Your new 4th Gen Tablo won't need these subscriptions. Unless you plan to continue to use your legacy Tablo device, you can cancel your legacy Tablo subscription/s. You can find out how to do so, here.
Premium Service and the Automatic Commercial Skip feature will be discontinued for all grandfathered users on December 31, 2026.
Set Up Your 4th Generation Tablo
You can physically swap your old legacy Tablo for your 4th Gen one. Your current TV antenna will be compatible.
If you're planning to continue using your legacy Tablo, you will need a second TV antenna or a splitter to connect your antenna to both Tablo units. Splitting your signal will reduce the overall signal strength coming to your Tablo devices, so you may need a more powerful TV antenna or a distribution amplifier to ensure both devices get strong signals from your TV antenna.  You will also want to rename your legacy Tablo so you can tell the two apart.
Once your Tablo is connected, download the 4th Gen Tablo app (dark blue) on your compatible iOS or Android mobile device and follow the setup steps. You can find more information about these steps, here.
You will need to create a 4th Generation Tablo account. This is separate from your legacy account. It's a free account whose only purpose is registration.
Download the 4th Generation App on Your Devices
Finally, make sure to download the 4th Generation Tablo app on all of your compatible smart TVs and streaming devices. When you launch the Tablo app, it will automatically detect and connect to your Tablo as long as it's on the same home network as your streaming device or smart TV.
Optional - Add A Larger Hard Drive
To expand your 4th Generation Tablo's storage, you can connect a 1 TB to 8 TB USB 2.0 or 3.0 hard drive and format it within the settings screen of the Tablo app. To get a grasp on how storage translates to play time, go here.
The process of connecting and formatting an external hard drive will delete all of the content on that drive. Legacy Tablo DVR recordings cannot be transferred to your 4th Gen DVR.
Hard drives smaller than 1TB, USB flash drives and network-attached storage are not compatible.
