Depending on which Tablo model you use, the apps and list of compatible devices may be different.
Before purchasing a Tablo device, please review the compatible devices listed below for your Tablo model. For even more foolproof assurance, simply search your smart TV or streaming device for the Tablo TV app to see if it is available.
Table of Contents
- Tablo Apps
- Compatible Devices for 4th Generation Tablo Models
- Compatible Devices for Legacy Network-Connected Tablo Models
- Compatible Devices for Legacy TV-Connected Tablo Models
Tablo Apps
Some apps can be downloaded to your device by clicking on the links below from your PC or mobile device. However, you may need to go to the app store on your specific streaming device or smart TV and search for 'Tablo' to find and download the app.
Legacy Tablo apps are not compatible with the new 4th Generation Tablo models and the new 4th generation Tablo apps are not compatible with legacy Tablo models.
You can differentiate the correct type of Tablo app for your device model by the app icons.
Tablo apps for 4th Generation Tablo models are light blue and white with a dark blue background. Tablo apps for legacy Tablo models are light blue and orange with white accents.
If you are not able to find the Tablo App on your device, it is likely not supported.
4th Generation Tablo Apps
- Tablo App on iOS*
- Tablo App on Android Mobile*
- Tablo App on Roku
- Tablo App on Amazon Fire TV
- Tablo App on Android TV
- Tablo App on Apple TV
- Tablo App on Google TV
- Tablo App on Samsung TV
- Tablo App on LG TV
Legacy Tablo Apps
- Legacy Tablo App on iOS*
- Legacy Tablo App On Android Mobile*
- Legacy Tablo App on Roku
- Legacy Tablo App on Amazon Fire TV
- Legacy Tablo App on Android TV
- Legacy Tablo App on Apple TV
- Legacy Tablo App for Windows
- Legacy Tablo App for web (http://my.tablotv.com)*
* Can be used for initial setup via Wi-Fi or Ethernet
Specific instructions for finding and downloading the Tablo app on different devices can be found here.
This includes the following Tablo models:
- Tablo 4th Generation (2-tuner & 4-tuner)
- Tablo Total System (2-tuner & 4-tuner)
Streaming devices:
- Roku*
- Amazon Fire TV
- Amazon Fire TV Cube (3rd generation)
- Amazon Fire TV Cube (2nd generation)
- Amazon Fire TV Cube (1st generation)
- Amazon Fire TV Stick Lite
- Amazon Fire TV Stick (3rd generation)
- Amazon Fire TV Stick 4K
- Amazon Fire TV Stick 4K Max
- Nvidia Shield (Android TV)
- Google TV Streamer
- Chromecast with Google TV (Android TV)
- ONN Google TV 4K Streaming Box
- Apple TV (HD & 4K models)
* Current generation Roku Express HD devices (3960) are not supported. Other older low-end Roku devices and those that do not support 4K (for example the Roku Streaming Stick 3800 and Roku Express+ 3910) are also not supported.
Smart TVs:
- Roku Smart TVs (Multiple Manufacturers)
- Amazon Fire TV Edition Smart TVs (Multiple Manufacturers)
- Smart TVs Running an Android TV Operating System (Multiple Manufacturers)
- Smart TVs Running a Google TV Operating System (Multiple Manufacturers)
- Samsung Smart TVs With Model Years 2019+ Running TIZEN OS 5+
- To find your Samsung's model number and manufacturing date, go here.
- LG smart TVs With Model Years 2019+ Running WebOS 4.
- To find your LG's model number and manufacturing date, go here
- Smart Insignia TVs using FireOS and Roku are supported. For specific device support, search for the Tablo on your Insignia’s TV’s app store
Mobile devices:
- iPads & iPhones Running iOS 15+
- Android Smartphones and Tablets Running Android 7.0+ or Fire OS 6+
- Amazon Fire Tablets
- Amazon Fire HD 7 (model years 2019+)
- Amazon Fire HD 8, HD 8 Plus (model years 2018+)
- Amazon Fire HD 10, HD 10 Plus (model years 2019+)
- Amazon Fire Max 11
- Tablo DUAL LITE
- Tablo DUAL 128GB
- Tablo QUAD
- Tablo QUAD 1TB
Streaming Devices:
- Roku
- Amazon Fire TV
Smart TVs:
- Smart TVs running an Android TV Operating System (Multiple Manufacturers)
Mobile devices and PCs:
- iPads & iPhones running iOS 12+
- Android smartphones and tablets running Android 4.4+
- Windows 10 PCs & MAC computers running the Safari or Firefox browsers
- Microsoft Edge (version 95+) and Chrome (version 123+) browsers have made changes that prevent the Tablo web app (http://my.tablotv.com/) from being supported.
Devices that are no longer supported for legacy network-connected models:
- Samsung TIZEN OS Smart TVs
- LG webOS Smart TVs
- Xbox
An active TV Guide Data Service subscription is required to access your legacy TV-connected Tablo on secondary TVs in your home via compatible devices.
- Tablo DUAL HDMI
- Tablo QUAD HDMI
Streaming Devices:
- Roku
- Amazon Fire TV
Smart TVs:
The following devices are NOT compatible with TV-connected Tablo models:
- Apple TV
- Smartphones or Tablets
- PC/MAC
- Smart TVs Powered By Samsung TIZEN or LG webOS
- Xbox
