NOTE - Legacy Tablo apps are no longer available for download. Many of the underlying technologies used by legacy Tablo apps and services are becoming obsolete and are no longer maintainable. Support was discontinued for all legacy Tablo apps on September 1st, 2026.
If you have a network-connected legacy Tablo model and have not completed the Legacy Transition steps, we urge you to do so and begin using the newer 4th Generation Tablo apps. These apps are built on modern technology, are easier to maintain and will receive ongoing updates.
Legacy Tablo models are previous-generation Tablo hardware, released between 2014 and 2021.
The following Tablo models are considered legacy devices:
Network-Connected Models:
- Original 2-Tuner Tablo OTA DVR
- Original 4-Tuner Tablo OTA DVR
- Tablo DUAL LITE OTA DVR
- Tablo DUAL 64GB OTA DVR
- Tablo DUAL 128GB OTA DVR
- Tablo QUAD OTA DVR
- Tablo QUAD 1TB OTA DVR
TV-Connected Models:
- Tablo DUAL HDMI OTA DVR
- Tablo QUAD HDMI OTA DVR
To read about the differences between our network-connected and TV-connected models, go here.
All legacy network-connected models need Firmware Update 2.2.60 to function. If your legacy network-connected Tablo has firmware earlier than 2.2.58 please update.
All network-connected models are compatible with the 4th Generation app through the Tablo Legacy Transition.
Not sure which Tablo model you have? This guide can help.
