Tablo FAQs – A Comprehensive List
Tablo David
Tablo David
Have a question about Tablo or want to know more about how Tablo works? This is a great place to start!
Table of Contents
Don't see an answer to your question? Just type it in the search bar at the top of the page to find another article that may help.
About 4th Generation Tablo Devices
What do I get when I buy a Tablo device?
The Tablo Total System comes with everything you need to start watching TV for free today, including the Tablo device (either 2-tuner or 4-tuner) with 50+ hours of onboard storage, a 35-mile TV antenna, power supply, Ethernet cable and free Tablo apps for every screen.
Already have a TV antenna? Choose the standalone 2-tuner or 4-tuner Tablo and save.
What channels can I get with a TV antenna and Tablo?
Most Americans can access major broadcast networks like ABC, CBS, NBC, FOX, PBS and the CW for free and in high definition with a simple TV antenna. Many additional 'subchannels' are also often available with unique content like throwback sitcoms, sci-fi favorites and westerns. See what antenna TV channels you can watch and record with Tablo in your area.
What live internet-based streaming channels can I get with Tablo?
Whether you’re into cooking, true crime, travel or sports, there’s a free streaming channel on Tablo for you. See a list of the 100+ free streaming channels you can watch.
How does Tablo work?
Tablo connects your TV antenna to your home router using Wi-Fi or Ethernet to stream live and recorded programming to all your internet-connected devices. This allows you to position your TV antenna wherever it gets the best signal.
Does Tablo come with a remote?
No. 4th Generation Tablo devices don’t need their own remote because you control Tablo using your existing streaming device or smart TV remote once the Tablo app has been downloaded.
How do I watch Tablo on my streaming device or smart TV?
Once you’ve completed the initial setup of your Tablo device, you simply need to search for and download the Tablo app in the app store on your streaming device or smart TV. The app will then find your Tablo on your home network and connect to it. Click here for device-specific instructions.
Do I need the internet to use Tablo?
Yes. You do need internet to use Tablo. Like many modern gadgets, Tablo is a network-connected device, designed to have consistent high-speed internet access and cannot update the guide or software without it.
That being said, the 4th Generation Tablo has an Offline Mode for when the internet goes down.
4th Generation Tablo devices come with 50+ hours of onboard HD storage. However, you can choose to connect a portable USB hard drive (USB 2.0 or 3.0) between 1 TB and 8 TB in size for up to 1000 hours of additional storage capacity.
No. Tablo is designed to stream and record broadcast TV from antennas as well as most of the included free TV streaming channels. It does not support viewing or recording from streaming services like Netflix, Sling or cable or satellite channels like ESPN or HGTV.
Does the 4th Generation Tablo support ATSC 3.0 (aka NextGen TV)?
No. The tuners in the 4th Gen Tablo support the ATSC (Advanced Television Systems Committee) 1.0 broadcast standard used by all major commercial broadcasts today, and the Tablo device takes full advantage of it like never before. While ATSC 3.0 broadcasts are available in some markets, ATSC 1.0 broadcasts will continue through at least June 2027.
We are working on a Tablo device that will be fully certified and compliant with all ATSC 3.0 requirements. Significant progress has been made, but as of yet, there is no ETA for this product.
Compatible Devices and Apps
To set up your Tablo, you'll need an iOS or Android smartphone or tablet.
What devices are compatible with Tablo for viewing and managing live TV and recordings?
Tablo is compatible with streaming devices (sticks and boxes) and smart TVs from Roku, Amazon Fire TV, Android TV/Google TV, Apple TV, Samsung and LG, as well as smartphones and tablets running iOS and Android.
Click here for links to all Tablo apps and device compatibility details for 4th Generation and legacy Tablo models.
How do I get the Tablo app for my device?
Visit our apps and compatible devices page for links to all Tablo apps.
4th Generation Tablo Features
Can I set series recordings with my Tablo?
Yes. One-touch recording of an entire TV series is available with Tablo. See a full overview of Tablo’s recording features here.
Can I time shift with Tablo (aka watch recordings on tape delay)?
Yes! You can begin watching in-progress recordings as little as 30 seconds after they’re set to start on the majority of Tablo apps.
Does Tablo support 5.1 Surround Sound?
Yes. Tablo supports the passthrough of 5.1 Surround Sound to devices capable of decoding this sound profile.
Does Tablo support closed captioning?
Yes! Tablo supports closed captioning on most platforms.
TV Antennas and Reception
Do I need a TV antenna to use a Tablo?
You do. The only way for Tablo to receive local broadcast channels is through a TV antenna.
What kind of TV antenna should I buy to use with Tablo?
Unfortunately, there's no one-size-fits-all answer. What kind of TV antenna will work best for you depends on the location and the distance of your local broadcast towers, the type of frequency on which your local channels are broadcast and potential sources of obstructions or interference. Check out this article for details.
Will the TV antenna that comes with the Tablo Total System work for me?
The TV antenna that comes with the Tablo Total System has an approximate range of 35 miles. This antenna should be sufficient for most users who:
  • Live less than 35 miles from their local broadcast towers
  • Have a window facing the towers where they can place the TV antenna
More powerful or specialized TV antennas may be required to receive all the channels broadcast in your area.
Where Should I Place My Antenna?
The keys to proper TV antenna placement are to place it as high as possible, facing the direction of your local broadcast towers. For indoor TV antennas, we recommend a spot on the top floor of your home, on or near a window facing your local broadcast towers. If that's not possible, or you live in a suburban or rural area, an outdoor TV antenna mounted on your roof or balcony may be a better solution. If you're not comfortable DIY-ing the installation, a professional TV antenna installer can assist. For further advice, go here.
Will Tablo help improve my TV antenna reception?
No. Tablo is a whole-home antenna TV DVR. It is not designed to boost antenna TV reception or help your existing TV antenna pick up more over-the-air TV channels. If your current TV antenna struggles to pick up one or more channels, it is advisable to improve the placement of your TV antenna or upgrade to a more powerful model.
Shipping & Returns
Shipping is always free to residents of the United States. We hope you love your Tablo, but if you're unhappy with it for any reason, we offer a 30-day money-back guarantee. Customers must pay for return shipping. See our store policies page for details.
Where does Tablo ship?
Current generation Tablo products are available to residents of the United States (including Alaska & Hawaii). See our store policies page for details.
About Legacy Model Tablo Devices
What are Tablo legacy models?
Tablo legacy models are older hardware devices, including the Tablo DUAL LITE, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB, Tablo DUAL HDMI, Tablo QUAD HDMI, as well as the original 2-Tuner and 4-Tuner Tablo DVRs.
What’s the difference between the 4th Generation Tablo and legacy Tablo models?
Legacy Tablo models were our old standbys, quality products with popular features. However, fully taking advantage of such required a TV guide data service subscription.
The 4th Generation Tablo is our latest whole-home network-connected device, which enhances the free TV experience for consumers who use an antenna to watch broadcast television. The 4th Gen Tablo offers a suite of fully revamped apps, onboard storage and the ability to watch additional free streaming channels on top of antenna TV content, all without any subscriptions or fees.
4th Generation Tablo apps are currently fully supported. However, if you own a legacy network-connected Tablo model (Tablo DUAL LITE, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB and the original 2 and 4 Tuner Tablo DVRs) legacy Tablo, your old apps will remain accessible to you but won’t be maintained or updated and are not available to download from app stores.
If I own a legacy Tablo model, do I still need a TV guide data service subscription to enjoy all of the features?
Legacy Tablo models still require a TV guide data service subscription to access advanced features via legacy Tablo apps. However, Tablo’s Legacy Transition Program is designed for owners of legacy network-connected Tablo devices to access and manage those DVRs via newer 4th Generation Tablo apps. 4th Generation Apps do not have, nor require, a subscription.
What's the difference between TV-connected Tablo OTA DVRs and network-connected Tablo OTA DVRs?
Network-Connected Tablo DVRs don’t connect to your television at all. Instead, they connect to your home’s Wi-Fi router to distribute live and recorded TV to multiple internet-connected devices like smart TVs, streaming boxes and sticks, smartphones and tablets. On the other hand, TV-connected DVRs are designed for people who primarily watch programming on a single television. They offer a more traditional DVR setup that connects directly to your television while at the same time providing the powerful yet easy-to-use DVR interface that Tablo customers know and love.
Do TV-connected Tablo OTA DVRs let me stream video to other devices?
While TV-connected Tablo OTA DVRs are designed for TV fans who primarily watch programming on a single television, they do enable streaming to a limited selection of internet connected devices within the home with an active TV Guide Data Service Subscription. Depending on the quality of your home network, TV-connected Tablo DVRs can stream to up to two (for the Tablo DUAL HDMI) or four (for the Tablo QUAD HDMI) compatible smart TVs or streaming set-top-boxes at the same time. They are not compatible with existing Tablo apps for computers, smartphones, tablets, Apple TV or select smart TVs.
Subscriptions (For Legacy Model Customers Only)
Does the 4th Generation Tablo require a subscription?
No. There are no subscriptions, contracts or hidden fees with the 4th Gen Tablo whatsoever. Programming from your TV antenna, as well as the 100+ included internet-based streaming channels, are absolutely free, and there is no cost to enjoy Tablo apps, features or guide data.
For legacy Tablo models, what does my Tablo TV Guide Data Service Subscription include?
For a small monthly fee, our TV guide data service subscription provides the beautiful cover art, episode and series synopses and metadata that makes it easy for you to browse content and set recordings on your legacy model Tablo through our various apps. A subscription also enables some of Tablo's cooler features, like Tablo Connect for out-of-home streaming. Get pricing here.
I have a legacy model Tablo. Can I stop paying for my TV Guide Data Service Subscription and still enjoy all the same features?
An active TV guide data service subscription will always be required to use advanced features on legacy Tablo models using legacy Tablo apps. However, Tablo’s Legacy Transition Program is designed for owners of legacy network-connected Tablo devices to access and manage those DVRs via newer 4th Generation Tablo apps. 4th Generation Apps do not have, nor require, a subscription. For further details, go here.
I have a legacy Tablo device. Can I stop paying for my Premium Service subscription and still enjoy Automatic Commercial Skip?
No. The Automatic Commercial Skip feature was sunset for new customers in 2022 and is not available in the new Tablo app experience. Premium Service subscribers must continue to pay for TV Guide Data Service and Premium Service to enjoy Automatic Commercial Skip on legacy Tablo devices and apps.
Can I apply my existing Tablo subscription to a 4th Generation Tablo?
No. 4th Generation Tablo products do not require or recognize subscriptions.
