Troubleshooting Connectivity Issues on a Legacy Tablo
This is a legacy article. For help troubleshooting connectivity issues for 4th Generation Tablo, go here.
If you are having connectivity issues with your legacy Tablo, many of them can be solved by using some of the basic troubleshooting techniques found below.
Rebooting the Tablo DVR
A regular reboot of your Tablo solves many minor problems and should always be your first troubleshooting step.
To reboot your Tablo DVR, quickly press and release the blue reset button on the back right of the unit. Wait for the Tablo's blue LED to stop flashing. When the blue LED is solid, the reboot is complete. None of your Tablo DVR's data or recordings will be deleted with this type of restart.
Power Cycle the Tablo DVR
If the reboot step above does not solve your issue, you can try power cycling your Tablo. To do this, remove the A/C power adapter from the back of the unit for ~10 seconds. Then re-attach the power adapter to the Tablo. The unit can take up to three minutes to boot up from this type of reset. None of your Tablo's data or recordings will be deleted with this type of reboot.
Power Cycle the Router
If the Tablo DVR reboot steps above do not solve your issue, you may be having connectivity-based issues. Try power cycling your router. To do this, remove the A/C adapter from the router for ~10 seconds. Then re-attach the power adapter to the router. The router can take a few minutes to boot up from this type of reset. Once your router is back online, repeat the Tablo reboot cycles noted above.
Disable any VPNs
The Tablo applications connect to your Tablo using a number of discovery methods. A VPN actively changes your network's IP address. This can cause discovery issues which can result in connectivity problems. We recommend disabling any VPNs while using Tablo.
Re-Syncing Applications
This step should only be taken if absolutely necessary.  We are discontinuing support for all legacy Tablo apps on September 1st, 2026. After this date, the legacy apps will no longer be available for download, so if you delete them, you will not be able to get them back.
If your problem persists through the above troubleshooting steps, try uninstalling and reinstalling the Tablo app on your viewing device. This will clear any cache or old data the application may have stored.
If you have deleted your legacy app and cannot get it back, you may be able to run the Legacy Transition to secure a 4th Gen one.
If these steps do not successfully solve your issue, we recommend consulting the Tablo Knowledge Base, Tablo Community, or Tablo Support team for further assistance.
