Troubleshooting Connectivity Issues On the 4th Generation Tablo
Tablo David
Tablo David
If you own a legacy Tablo, please click here for troubleshooting steps.
If you are having issues connecting to your 4th Generation Tablo, many of them can be solved by using some of the basic troubleshooting techniques found below.
If you encounter any screens or errors that indicate your Tablo is "not found" or your Tablo app is unable to locate the Tablo, try using the steps below to resolve the issue.
Rebooting the Tablo DVR
A regular reboot of your Tablo solves many minor problems and should always be your first troubleshooting step.
To reboot your Tablo DVR, quickly press and release the white reset button on the bottom of the unit. DO NOT HOLD THE BUTTON DOWN.
Wait for the Tablo's blue LED to stop flashing. When the blue LED is solid, the reboot is complete. None of your Tablo DVR's data or recordings will be deleted with this type of reboot.
If the Tablo's blue LED continues to flash ~2 minutes after the reboot, this indicates the unit is not able to reach our server and is likely experiencing a networking issue.
Power Cycle the Tablo DVR
If the reboot step above does not solve your issue, you can try power cycling your Tablo. To do this, remove the A/C power adapter from the back of the unit for ~30 seconds. Then re-attach the power adapter to the Tablo. The unit can take up to 3 minutes to boot up from this type of reset. None of your Tablo's data or recordings will be deleted with this type of reboot.
Power Cycle the Router
If the Tablo DVR reboot steps above do not solve your issue, you may be having connectivity-based issues. Try power cycling your router. To do this, remove the A/C adapter from the router for ~10 seconds. Then re-attach the power adapter to the router. The router can take a few minutes to boot up from this type of reset. Once your router is back online, repeat the Tablo reboot cycles noted above.
Check Your Network Connections
Guest networks are offered on almost all home Wi-Fi routers. This network type allows external internet access, but blocks device-to-device communications. So, if your smart TV, streaming, or mobile device is working fine with internet-based streaming services but can't connect to your Tablo, making sure your viewing device isn't connected to the guest portion of your home network should help.
Force Close or Reinstall Applications
If your problem persists through the above troubleshooting steps, try force-closing or reinstalling the Tablo app on your viewing device. This will clear any cache or old data the application may have stored.
Disable any VPNs
The Tablo applications connect to your Tablo using a number of discovery methods. A VPN actively changes your network's IP address. This can cause discovery issues which can result in connectivity problems. We recommend disabling any VPNs while using Tablo.
If these steps do not successfully solve your issue, we recommend consulting the Tablo Knowledge BaseTablo Community or Tablo Support team for further assistance.
