When you first set your Tablo up, you will be walked through running your very first channel scan, but there may be other times when a new channel scan is needed:
- When you re-position your antenna due to reception issues
- If a new station becomes available in your area
- To get the most up-to-date information regarding signal strength
To run a new channel scan, you will first need to connect to your Tablo using the Tablo app on iOS, Android, Roku, Fire TV, Apple TV, or by using the Tablo Web App in your browser (Google Chrome, Safari, or Microsoft Edge recommended). Once connected, open the menu and select the "Settings" option.
Scroll down until you find the "Guide" section of your settings. Here's what this area look like on the web app in your browser:
Select the "Edit Channel Lineup" button to open a list of the channels currently in your lineup:
If you simply wish to remove a channel from your lineup, you can deselect it using the checkbox on the left. Once you're done, remember to click "Add to Guide" to save your changes. To begin a new channel scan, click the "Rescan" button and the scan will begin.
While the scan is in progress, the "Add to Guide" button will remain inactive. Once the scan is finished, you'll notice some channels will be automatically selected, while others will be deselected. Tablo will, by default, choose the high definition (HD) version of a channel over its standard definition (SD) counterpart, as seen with channels 6-1 and 6-2 in the scan above. Your Tablo will also deselect any channel that it identifies as having problematic reception.
When you've finished selecting the channels you want in your guide, click the "Add to Guide" button to finish the process. You will be returned to your settings page, and a new guide update will begin downloading.
We recommend running a new channel scan once per season. If a broadcaster adds a channel in your area or changes which frequency they broadcast an existing station on, running a regular channel scan will ensure you stay up to date on these potential content changes.
Comments
