This is a legacy article, there are currently no 4th Generation Tablo apps compatible with laptops or desktops.
NOTE - Legacy Tablo apps are no longer available for download. Many of the underlying technologies used by legacy Tablo apps and services are becoming obsolete and are no longer maintainable. Support was discontinued for all legacy Tablo apps on September 1st, 2026.
The web app (my.tablotv.com), and Windows App will continue to be available but will also not be maintained or updated.
If you have a network-connected legacy Tablo model and have not completed the Legacy Transition steps, we urge you to do so and begin using the newer 4th Generation Tablo apps. These apps are built on modern technology, are easier to maintain and will receive ongoing updates.
Apple computer users can access the Tablo web app at http://my.tablotv.com/ via the Safari browser.
Support for the web app on Windows PCs via Chrome browser has ended in favor of Tablo's Windows 10 app.
As of version 95.0. the Microsoft Edge browser has made changes that prevent the Tablo web app (http://my.tablotv.com/) from being supported on this browser however, Firefox is still supported on Windows.
The Tablo account portal at https://account.tablotv.com/ (for subscription management) is supported on both MAC and PC via Safari or Firefox.
If you are using a supported browser and run into any issues, make sure your browser is up to date and disable any plugins your browser is running.
If you continue to experience any unexpected errors while using either the Tablo Web App or Tablo Subscription portal, make sure you are using a supported browser/operating system combination.
While other browsers may function, they have not been optimized and can cause problems.
