Advanced Recording Features for 4th Generation Tablo DVRs
This is a 4th Generation article. For information on Advanced Recording Features for legacy models, go here.
Recording your favorite shows with Tablo is easy. But sometimes, you may need to customize your recording schedule to better meet your needs.
For example, when your favorite show frequently airs after a sporting event, you can use an Advanced Recording Feature to add time to your recording schedule in case the game goes into overtime.
4th Generation Tablo users can access these options for free, whereas legacy models need a subscription to take full advantage of them.
To see Advanced Recording Features, select a series from the Shows, Movies or Sports tabs. This will bring up the Series Information screen. Here, select Recording Options.
In the Live TV Grid, you can access the Series Information Screen by selecting its button after selecting the show.
Advanced Recording Features Available
Start
With this feature, you can start recordings up to ten minutes early to two minutes late from the show's scheduled start time. This is handy if you want an opening buffer or wish to skip the show's opening credits.
Stop
With this feature, you can stop recordings up to two minutes early to three hours late from the show's scheduled stop time. This is handy for when you expect a sporting event to go into overtime or when you'd like to skip the end credits of a show.
Keep
The keep feature helps to manage your recording storage space automatically.
Enabling the keep feature on programs that air frequently (like talk shows, game shows, and news) will tell your Tablo to retain only the most recent 20, 10, 5, 3 or last single airing(s). Older episodes are deleted automatically from the series as new ones are added, so your recording storage space isn't cluttered with out-of-date content.
Instead of using the Delete All or Delete Watched options, you can enable the keep feature temporarily to delete some, but not all, older recordings within a series.
However, the keep All setting should be used sparingly. If you set a keep level of All or Last 20 Episodes on too many series, recordings in other series could be removed prematurely if you also have auto-delete enabled.
Channel
If you live between broadcast areas, you may have two different channels broadcasting the same content. If you notice that one channel tends to receive more reliable reception than another, this feature allows you to choose that specific channel for recording.
If you select All Channels, the channel airing this series with the strongest signal at your last channel scan will be used.
Use Defaults
If you'd like to switch your Advanced Recording Features back to their original values, select USE DEFAULTS.
  • Keep: will be set to Auto (Default)
  • Start: will be set to On Time
  • Channel: will be set to Any (Default)
  • Stop: Will be set to On-Time
As a default feature, your Record setting will not change when you revert to defaults for the Advanced Recording Features.
