Table of Contents
- About Tablo Apps
- 4th Generation vs. Legacy Apps
- 4th Generation Apps and Compatible Devices
- Legacy Network-Connected Tablo Apps and Compatible Devices
- Legacy TV-Connected Tablo Apps and Compatible Devices
About Tablo Apps
Tablo doesn’t connect directly to your TV. Instead, it connects to your home Wi-Fi router to send your antenna TV signal wirelessly to Tablo apps on compatible devices throughout your home.
The Tablo app will not come pre-installed on your smart TVs, streaming devices, smartphones and tablets. You’ll need to visit the app store on each device and download the Tablo app before you can access your DVR, play programs and set recordings.
Tablo apps each share similar navigation and functionality across different platforms, but there are some small differences in features or behavior on certain compatible devices.
Tablo apps are designed to work with a wide variety of current smart TVs, mobile and streaming devices. However, older device models may not have enough memory or processing power to run the Tablo app smoothly or may no longer be supported. For the best Tablo experience, we recommend updating your streaming devices with newer models every five years.
You can determine the correct Tablo app for your device model by the app icon.
Apps for 4th Generation Tablo models have a dark blue background with white and light blue accents. Apps for legacy Tablo models have a white background with light blue and orange accents.
Legacy Tablo apps are not compatible with 4th Generation Tablo apps, but legacy network-connected Tablo devices can also use 4th Generation apps once you’ve enabled the Legacy Transition on your device.
Verify that your smart TV and streaming devices are compatible with Tablo before you buy. Simply search for the Tablo app on your device’s app store. If you cannot find the correct Tablo app, your device is not directly compatible.
4th Generation Tablo apps are currently fully supported. However, if you own a legacy network-connected Tablo model (Tablo DUAL LITE, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB and the original 2 and 4 Tuner Tablo DVRs) legacy Tablo, your old apps will remain accessible to you but won’t be maintained or updated and are not available to download from app stores.
4th Generation Tablo Apps and Compatible Devices
* Mobile apps are required for initial setup via Wi-Fi or Ethernet.
Specific instructions for finding and downloading the Tablo app on different devices can be found, here.
4th Generation Tablo-Compatible Devices
Before purchasing a 4th Generation Tablo, please review the list of compatible smart TVs, streaming devices, smartphones and tablets. To confirm compatibility, simply search your smart TV or streaming device for the Tablo TV app to ensure it is available.
4th Generation Tablo-Compatible Streaming Devices
Roku – Roku streaming sticks and boxes are the most popular devices used by Tablo customers. Most current devices are compatible except for:
- HD-only Roku streaming sticks may exhibit intermittent issues with displaying content and are generally not supported.
- Low-end Roku devices and those that do not support 4K (for example, the Roku Streaming Stick 3800 and Roku Express+ 3910) are also not supported.
Amazon Fire TV - Amazon Fire TV streaming sticks and boxes are also popular with Tablo customers. Most current devices are compatible except for those that run the new Vega operating system:
- The 2025 Amazon Fire TV 4K Select streaming stick (unsupported)
- The 2026 Amazon Fire TV Stick HD (unsupported)
Android TV/GoogleTV – These devices are growing in popularity and can be very affordable. All current devices are compatible, including:
- Nvidia Shield
- Google TV Streamer
- Chromecast with Google TV
- ONN 4K Streaming Device
- ONN 4K Pro Streaming Device
- Apple TV (HD & 4K models) - For Apple fans, Apple TV streaming devices are a great choice. All current Apple TV devices are compatible.
NOTE: Other devices, including generic Android streaming boxes, may offer a Tablo app without official support. All supported devices are regularly tested for compatibility with app and platform updates.
Smart TVs:
- Roku Smart TVs (Multiple Manufacturers)
- Amazon Fire TV Edition Smart TVs (Multiple Manufacturers)
- Smart TVs Running an Android TV Operating System (Multiple Manufacturers)
- Smart TVs Running a Google TV Operating System (Multiple Manufacturers)
- Samsung Smart TVs With Model Years 2019+ Running TIZEN OS 5+
- To find your Samsung's model number and manufacturing date, go here
- LG smart TVs With Model Years 2019+ Running webOS 4.
- To find your LG's model number and manufacturing date, go here
- Smart Insignia TVs using FireOS and Roku are supported. For specific device support, search for the Tablo on your Insignia’s TV’s app store
NOTE - Tablo does not currently support Vizio smart TVs. Owners of this brand of televisions should purchase and install a compatible streaming TV device to access Tablo. Other devices, including smart displays, may offer a Tablo app but are not officially supported.
Mobile devices:
- iPads & iPhones Running iOS 15+
- Android Smartphones and Tablets Running Android 7.0+ or Fire OS 6+
- Amazon Fire Tablets
- Amazon Fire HD 7 (model years 2019+)
- Amazon Fire HD 8, HD 8 Plus (model years 2018+)
- Amazon Fire HD 10, HD 10 Plus (model years 2019+)
- Amazon Fire Max 11
If you own a legacy network-connected Tablo model (Tablo DUAL LITE, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB and the original 2 and 4 Tuner Tablo DVRs) legacy Tablo, your old apps will remain accessible to you but won’t be maintained or updated and are not available to download from app stores.
If you have a network-connected legacy Tablo model and have not completed the Legacy Transition steps, we urge you to do so and begin using the newer 4th Generation Tablo apps. These apps are built on modern technology, are easier to maintain and will receive ongoing updates.
Legacy Tablo Apps
- Roku – Available for download but no longer supported
- Amazon Fire TV – App Delisted
- Android TV/Google TV – App Delisted
- Apple TV – App Delisted
- iOS mobile 12+ – App Delisted
- Android mobile 4.4+ – App Delisted
- Tablo web app at my.tablotv.com – App partially available via Safari + Firefox browsers*
- Windows 10 – Available for download but no longer supported
- LG webOS – App Delisted
- Samsung TIZEN – App Delisted
- Xbox – Available for download but no longer supported
*Microsoft Edge (version 95+) and Chrome (version 123+) browsers have made changes that prevent the Tablo web app from being supported.
If you own a legacy TV-connected Tablo model (DUAL HDMI and Tablo QUAD HDMI), your Tablo’s onboard interface and the legacy Tablo apps that support in-home streaming will remain accessible but are not maintained or updated. Legacy Tablo apps (except for Roku) are not available for download from app stores.
Tablo DUAL HDMI and QUAD HDMI owners can continue to use the Tablo’s onboard interface and the legacy Tablo apps that support in-home streaming from TV-connected Tablo devices as long as those apps remain functional.
However, since TV-connected legacy Tablo devices cannot transition to using 4th Generation Tablo apps, it may be advisable to upgrade to a 4th Generation Tablo device if you would like to maintain long-term whole-home functionality.
Legacy Tablo Apps Compatible with TV-Connected Tablo DVRs
The following apps and devices are NOT compatible with TV-connected Tablo models:
- Apple TV
- Smartphones or Tablets
- PC/MAC
- Smart TVs Powered by Samsung TIZEN or LG webOS
- Xbox
