This is an article for legacy network-connected Tablo. To find the 4th Generation Tablo Quick Start Guide, go here.
The Tablo Wi-Fi setup may look different than your Quick Start guide, if you are using a device on iOS 13 or above you can find this Wi-Fi setup guide here.
NOTE - Legacy Tablo apps are no longer available for download. Many of the underlying technologies used by legacy Tablo apps and services are becoming obsolete and are no longer maintainable. Support was discontinued for all legacy Tablo apps on September 1st, 2026.
If you have a network-connected legacy Tablo model and have not completed the Legacy Transition steps, we urge you to do so and begin using the newer 4th Generation Tablo apps. These apps are built on modern technology, are easier to maintain and will receive ongoing updates.
You can get a PDF copy of this guide here.
