Replacement Power Supplies
Before you buy a replacement power supply, consider the troubleshooting steps here, they could save you time and money.
If you suspect the power supply on your Tablo DVR has failed (or your cat decided to use it as a toy) you can purchase a new one:
  • Click here, for 4th Generation compatible power supplies.
  • Click here, for power supplies compatible with legacy Tablo 2-Tuner, Tablo 4-Tuner, Tablo DUAL 64, Tablo DUAL 128GB, Tablo QUAD, and Tablo QUAD 1TB OTA DVRs.
