What’s Included in Tablo’s Smart Scheduling Features?
The following Smart Scheduling features are both enabled by default on 4th Generation and legacy Tablo devices but can be turned off in SETTINGS.
Don't Record Duplicates
  • Prevents Tablo from recording duplicates.
  • Will record HD (high definition) in favor of SD (standard definition) if both formats are available.
  • If two episodes are available, it will pick the broadcast with the highest signal strength.
Auto Extend Live Recordings
  • Automatically extends recording time for airings marked as 'live' (including sports and specials).
  • When enabled, 4th Generation Tablo will add 30 minutes to live recordings and season/series finales. If you need to add more than 30 minutes to any recording schedule, you can do so using the advanced recording options.
  • When enabled, legacy Tablo devices running firmware 2.2.58+ will also add 30 minutes to live recordings. This was previously 50% of the total scheduled time, up to a maximum of 2 hours in older firmware versions.
