How Do I Get My Legacy Tablo's Live TV Grid Guide to Show 14 Days of Data?
This article's contents apply to the legacy network-connected and TV-connected Tablo DVRs. The 4th Generation Tablo apps automatically display 14 days of guide data in the Live TV grid.
If you are not seeing all 14 days of guide information in your Live TV grid on your legacy Tablo device, there are a few reasons why this could be:
  • Your 30 day trial subscription has ended and you do not have an active TV Guide Data Service subscription.
  • This feature has not been enabled within your Tablo app’s SETTINGS screen.
  • You are using an app that is limited to showing 24 hours of data in the Live TV grid (In this case, the remaining 13 days of guide data can be found in the Prime Time, TV Shows, Sports and Movie sections).
Look below for a breakdown of compatible Tablo apps and the type of Live TV grid available for said app.
Table of Contents
Android Mobile, Apple TV and Web/Windows 10
These legacy Tablo apps will only show 24 hours of data within the Live TV Grid guide. The remaining 13 days of guide information can be found in the PRIME TIME, TV SHOWS, MOVIES & SPORTS sections of your Tablo app. From there, you can browse airings occurring over the next 14 days and schedule recordings.
Roku (Smart TVs and Streaming Devices)
On Roku, customers with active TV Guide Data Service subscriptions can enable an enhanced Live TV Grid guide which displays all 14 days of data by turning on the 14-DAY LIVE TV GRID (BETA) feature found in the SETTINGS screen. If your streaming TV device is older, or if your network is slower, this could slow down navigation within the Live TV grid. If you find this is the case, you can easily disable this feature and return to the standard 24-hour view.
Graphical user interface, application
Description automatically generated
iOS (iPhone/iPad), Amazon Fire TV, Android TV, Tablo DUAL HDMI or QUAD HDMI Interfaces
By default, these Tablo apps and interfaces will show 14 days in the Live TV grid with an active TV Guide Data Service subscription.
How to Skip Ahead to Upcoming Days
If your Tablo app or interface supports a 14 day Live TV grid and you have an active TV Guide Data Service subscription, you can easily skip ahead to upcoming days in the grid by highlighting the date row at the top of the grid and hitting the RIGHT button on your remote's directional pad.
