How Much Space Does Tablo Require to Record a Program?
The amount of space a recording uses depends on the Tablo model you have.
Table of Contents
Recording Storage Space Usage for 4th Generation Tablo Models
Since 4th Generation Tablo models deliver and record OTA (over-the-air) TV in either the original uncompressed MPEG2 broadcast format or MPEG4 after archiving, when using onboard storage, recording file sizes can vary.
The following chart is an approximation of OTA recording storage usage for onboard storage on a 4th Generation Tablo vs. a 1TB external hard drive.
  Average Bandwidth Average Gigabytes/Hour (OTA)
Onboard Storage 3 Mbps 1.35 GB/hr
External Storage (1TB) 9 Mbps 4.05 GB/hr
This next chart is an approximation of free streaming recordings storage usage. This is identical for onboard and external storage on the 4th Generation Tablo models. Bandwidth varies as free streaming channels are delivered at a bit rate that adapts to your external internet speed to avoid buffering.
Onboard OR External Storage .5 Mbps – 5 Mbps 2.0GB/hr
Recording Storage Space Usage for Legacy Network-Connected Tablo DVRs
Depending on the recording quality setting you have selected for your legacy network-connected Tablo, you'll use between 2 and 4 GB per hour of recorded TV. For example, a 1 TB drive can record up to 700 hours of HD programming.
 Recording Quality
HD 1080
(720@60fps)
HD 1080
HD 720
 HD 720
SD 480
Bandwidth
10 Mbps
8 Mbps
5 Mbps
3 Mbps
2 Mbps
Gigabytes/Hour
4.6 GB/hr
3.7 GB/hr
2.4 GB/hr
1.5 GB/hr
1 GB/hr
Recording Storage Space Usage for Legacy TV-Connected Tablo DVRs
Since legacy TV-connected Tablo DVRs deliver and record OTA TV in its original, uncompressed MPEG2 format, its recorded files can be much larger than those of network-connected Tablo DVRs.
 MPEG2 Native
Broadcast
HD 1080
HD 1080
HD 720
Max Bandwidth
20 Mbps
15 Mbps
3 Mbps
Gigabytes/Hour
9.2 GB/hr
6.9 GB/hr
1.4 GB/hr
