4th Generation Tablo - How to Change or Edit Your Location
Tablo David
Tablo David
Your Tablo’s location is set during initial setup of your device.
This location is used to match the local channels you receive during a channel scan with TV guide data for your area. In most cases, this is a setting you'll never have to change.
However, if you move to a new city or take your Tablo to a vacation spot with its own TV antenna and internet, you'll have to change or edit your location.
Here’s how:
1. Open the 4th Generation Tablo app on your iOS or Android smartphone or tablet. This setting cannot be changed from a TV-based app.
2. Go to SETTINGS->GUIDE -> LOCATION.
3. Then SELECT NEW LOCATION.
4. Enter your 5-digit ZIP code and select SUBMIT.
5. Run and save a new a Channel Scan. Without this step, your location will not be updated.
Accessing the Location Setting From TV-Based Apps
As mentioned, changing or editing your location on your Tablo device can only be done via mobile apps.
If you visit SETTINGS -> GUIDE -> LOCATION in a TV-based Tablo app, a QR code will be displayed which, when scanned, will direct you to the instructions above.
