How to Use Favorites on the 4th Generation Tablo
Tablo Support - Lauren
4th Generation Tablo apps allow you to set channels as favorites, making them easy to access within the Home Screen and Live TV Grid.
Adding and Removing Favorite Channels
To add or remove a channel from your favorites list, select a program airing on a channel you wish to add or remove from the list.
Select ADD CHANNEL TO FAVORITES.
If you have already added the channel to the favorites list and are removing it, the option will show Remove Channel From Favorites.
How to use the Favorites Feature
You can find your favorite channels in the following places:
The Home Screen
On the Home Screen, scroll down to see the Your Favorites shelf.
This shelf features what’s airing live on your favorited channels. Use it as a quick way to get to your most-watched shows, movies and sports.
If you have not set your favorite channels, this shelf will be hidden.
The Favorites Category
If you're on the Live TV Grid, in the Category View, you can find the Favorites category right under Featured.
The Favorites Filter
If you want to filter your Live TV Grid so that it only shows your favorites, select GUIDE OPTIONS in the top left of the LIVE TV GRID.
Select FAVORITE CHANNELS.
The guide will now display only the stations added to your favorites.
If you're in the Channels View this filter is the only way to view favorites in the Live TV Grid
If you're not seeing channels that you've added to your guide in SETTINGS within the Live TV grid, make sure you haven't applied Favorites or another view filter.
To disable the Favorites Filter, navigate to GUIDE OPTIONS and select ALL CHANNELS.
