How To Use the Favorites Filter on the 4th Generation Tablo
Tablo Support - Lauren
Tablo 4th Generation supports setting channels as a favorite, allowing them to be easily accessed within the live TV grid.
Adding and Removing Favorite Stations
To add or remove a station from your favorites list:
Navigate to LIVE and select a program from the channel you wish to add or remove from your favorites list.
Select ADD CHANNEL TO FAVORITES.
If you have already added the channel to the favorites list and are removing it, the option will change to REMOVE CHANNEL FROM FAVORITES.
How to use the Favorites Filter
To view and quickly access your favorite stations:
Select CHANNELS at the top left of the live TV grid.
Select FAVORITE CHANNELS.
The guide will now display only the stations added to your favorites.
If you do not see many channels in your live TV grid that have been added to your channel lineup, verify that the Favorites Filter has not been enabled.
When the Favorites Filter is enabled, the CHANNELS button will be replaced with a FAVORITES button.
To disable the Favorites Filter, navigate to FAVORITES > ALL CHANNELS.
