How to Set Recordings on Tablo 4th Generation
Tablo Support - Kyle
NOTE: The following applies to 4th Generation Tablo devices (white). If you have a legacy Tablo device (black), please see the link here.
Tablo 4th Generation relies on the TV Guide Data it downloads each night to schedule recordings.
All 4th Generation Tablo devices come with a rolling 14 days of guide data included with the purchase of the unit at no additional cost.
Two types of recordings can be set on 4th Generation Tablos, one-time, and series. All types of recordings also have additional advanced recording options to fine-tune your scheduling.
One-time Recordings
1. From the Tablo app, navigate to any one of the following pages: Live, Shows, Movies or Sports.
2. Select the show you are interested in recording.
If you are navigating from the Shows or Sports guide screens instead of the live TV grid, you may need to scroll down to select the specific episode/airing you wish to record.
3. Select RECORD EPISODE.
Series Recordings
3. Select SCHEDULE SERIES RECORDING
4. Select ALL EPISODES or NEW EPISODES. New Episodes will not include reruns.
NOTE - Series recordings are not available on one-time airings such as special events.
Advanced Recording Options
Recording options allow you to customize how a series is recorded. It provides the following options:
  • Record All or New Episodes
  • Start and End the recording early or late
  • Keep a specified number of episodes before deleting the oldest first
  • In cases where an airing is present on multiple channels, specify which channel you wish to record from
You can access recording options by navigating to TABLO > LIBRARY > SCHEDULED > SELECT A SHOW > SERIES RECORDING OPTIONS.
If you wish to remove all advanced recording options from a series, you can select USE DEFAULTS.
