4th Generation Tablo DVRs and legacy Tablo DVRs come equipped with dual-band Wi-Fi. This enables your Tablo to connect to your home's router wirelessly if you are not able to connect it directly via Ethernet. This is especially helpful when the best location for your TV antenna is not near your Wi-Fi router.
Once your Tablo is connected to your router, it can then stream live and recorded content to all of the compatible devices on your home network.
All Tablo DVRs support both 2.4 and 5 GHz Wi-Fi band connections. To see what that means, go here.
