Don't Record Duplicates:
- Prevents Tablo from recording duplicates
- Will record HD in favor of SD if both formats are available
- If two episodes are available it will pick the broadcast with the highest signal strength
- Smart Scheduling will be enabled by default but can be turned off within the Settings tab
Auto Extend Live Recordings:
- Automatically extends recording time for airings marked as 'live' (including sports and specials)
- When enabled, Tablo will add 50% of the total scheduled time for Live recordings and season/series finales, up to a maximum of 2 hours
- Auto Extend Live will be enabled by default but can be turned off within the Settings screen
Comments
