Instructions for Connecting Legacy Tablo to Wi-Fi With Android 9 (and Below)
Tablo David
Tablo David
This article contains instructions for connecting legacy Tablo DVRs to Wi-Fi using the legacy Tablo Android app.  For instructions on how to add a 4th Gen Tablo to your network via Wi-Fi and Android, visit this article.
Once you have taken your Tablo out of the box and you have attached the power, antenna and hard drive, you are ready to set up Tablo via Wi-Fi.
Begin by downloading the legacy Tablo app from the Google Play Store, then open the Tablo app on your Android phone or tablet.
When you open the Tablo app, you will be taken to the main Add a New Tablo screen. Select Add Via WI-FI.
Select Continue on the prompt that appears.
Select Continue to allow permissions when prompted.
Select your home network and enter its password.
Once you have typed in your password, hit enter to continue.
Wait up to three minutes. Your Tablo's blue LED should stop pulsing and turn solid blue. When it does, this means your Tablo has now joined your Wi-Fi network. Your Android phone/tablet and the rest of your devices should now be able to connect to the Tablo.
