Before you buy a replacement power supply, consider the troubleshooting steps here, they could save you time and money.
If you suspect the power supply on your Tablo DVR has failed (or your cat decided to use it as a toy) you can purchase a new one:
<%= block.description %>
<% } %><%= block.description %>
