How much space does Tablo require to record a program?
Depending on the recording quality setting you have selected for your Tablo, you’ll use between 2 and 4 Gigabytes per hour of recorded TV.  For example a 1 TB drive can record between 250 and 500 hours of HD programming.
 Recording Quality
HD 1080
(720@60fps)
HD 1080
HD 720
 HD 720
SD 480
Bandwidth
10 Mbps
8 Mbps
5 Mbps
3 Mbps
2 Mbps
Gigabytes/Hour
4.6 GB/hr
3.7 GB/hr
2.4 GB/hr
1.5 GB/hr
1 GB/hr
Was this article helpful?
1 out of 1 found this helpful
Comments
Powered by Zendesk
