Closed Captions
Tablo supports closed captioning on the majority of its platforms including iOS smartphones and tablets, Android smartphones and tablets, Roku, Android TV, Amazon Fire TV, Apple TV, Xbox One, and the web app at my.tablotv.com.
The interface of TV-connected Tablo DVRs also supports this feature.
iOS Smartphones and Tablets
To enable, simply select the closed captioning button in the bottom right of the player
Android Smartphones and Tablets
To enable, simply select the closed captioning button in the top right of the player.
Roku
To enable, simply select the star (*) button on the Roku remote and select 'on' for captions mode.
Apple TV
To enable on the 4th Generation Apple TV, use the remote to swipe down from the top and select 'Subtitles' and then 'CC'.
Android TV
To enable, press down for settings.
Amazon Fire TV
Tablo's Web App
To enable, select the closed captioning button in the player.
Tablo's Samsung TIZEN Smart TV App
To enable, on your Samsung Smart TV's menu go to SETTINGS > SYSTEM > ACCESSIBILITY -> CAPTION > ON.
TV-Connected Tablo DVR Interface
To enable, press down for settings on your Tablo HDMI remote.
The Exception
Tablo does not support closed captioning via the LG Web OS app as the player software does not allow it.
Make sure to follow us on Facebook or Twitter for updates and if there are any other improvements for this feature you'd like to see, let us know!
Comments
