Sources of Obstructions and Interference for Antenna TV
Along with your TV antenna and location, the next critical aspect in your ability to receive free over-the-air (OTA) TV is the presence of obstructions or sources of interference between your antenna and local broadcast towers.
Visible obstructions and/or invisible sources of interference can cause errors in the broadcast TV stream, resulting in audio dropouts/, pixelation and stuttering in the video.
Unlike analog TV, a digital OTA TV picture won’t degrade slowly into ‘snow’, it will often just stop – something known as the digital cliff.
That’s why obstructions and interference can have a huge impact on the number of channels you’re able to receive and the reliability of those broadcasts.
If you use an OTA DVR like Tablo, obstructions and interference can also cause your recordings to fail.
Common Sources of Over-the-Air TV Obstructions
In general, obstructions are visible impediments affecting the line-of-sight between your local broadcast towers and your over-the-air TV antenna.
Common obstructions include:
Mountains & Valleys
If your local broadcast tower is behind a mountain or you live in a deep valley, obtaining a good OTA TV signal will be problematic, as the signal’s line-of-sight will be blocked or will pass right over your TV antenna.
Trees
Trees can also block OTA TV reception, especially in the spring/summer when increased foliage and wind can cause the breakup of over-the-air TV video.
Large Buildings
If a large concrete office building sits between you and your local broadcast towers, your TV reception may also be blocked. Buildings with mirrored exteriors can also create multipath interference as signals are refracted or bounced off the shiny surfaces.
Your Home’s Construction Materials
Just like cell phone and satellite radio signals can’t penetrate parking garages, concrete and rebar construction or mesh stucco walls, neither can over-the-air TV signals.
Over-the-Air antennas should never be placed in basements or on windows with metallic film, security bars or mesh, as this will obstruct signals. They should also not be placed in attics with a radiant heat barrier or a metal roof.
Common Sources of Over-the-Air TV Interference
Just as visible obstructions can impact your over-the-air TV signal, invisible sources of interference can also affect your over-the-air reception.
Common sources of interference include:
Power Lines
Even if it’s not directly in front of your OTA TV antenna, overhead power lines leading to your house or high-tension lines in your backyard can reflect signals from broadcast towers, decreasing your antenna’s capacity to clearly ‘see’ them.
LTE Cell Towers
Traffic from nearby LTE cellular towers can also create invisible interference. Good quality TV tuners (like the ones in Tablo DVRs) and some antennas can have some built-in LTE filtering, but the addition of LTE filter antenna accessories can also help mitigate this.
LED Lightbulbs
If your OTA TV signal gets worse at night, try turning off the lights. While newer, good-quality LED lightbulbs certified by the FCC should not cause any interference with your OTA TV signals, older or lower-quality bulbs can create enough radio frequency (RF) interference to block signals.
Weather
To a lesser and far more variable degree, weather can affect your OTA TV signal, especially severe fog/rain/snow and large temperature swings, as the signal reflects off moisture in the atmosphere.
Being aware of potential impacts on your OTA TV signal and avoiding them when possible is important when switching to antenna TV.
