Tablo DUAL & QUAD HDMI Remote Features & Functions
Since the Tablo DUAL HDMI or Tablo QUAD HDMI’s interface is running on the DVR itself, it comes with its own dedicated IR (infrared) remote. It is capable of integrating with your television to control power and volume via CEC.
The remote takes 2 AAA batteries which are included in the box.
NOTE - This remote is NOT compatible with network-connected Tablo DVRs.
Tablo DUAL & QUAD HDMI Remote Functions
The primary functions of Tablo DUAL & QUAD HDMI's remote are as follows:
Power User Shortcuts
  • Just Press Play for Live - Skip secondary menus and start playback of the selected channel in the live TV grid by hitting PLAY instead of OK
  • Just Press Play for Recordings - Skip secondary menus and start playback of an individual recording or a series of recordings by hitting PLAY instead of OK
  • Zip Through Menus - Use FFWD or REW to quickly zip through most menus
Was this article helpful?
0 out of 0 found this helpful
Comments
Powered by Zendesk
