The Tablo web app at http://my.tablotv.com/ (to use your Tablo on your computer) and Tablo account portal at https://account.tablotv.com/ (for subscription management) are supported on Chrome, Safari, and Microsoft Edge.
If you are using any of these browsers and run into any issues, make sure your browser is up to date and disable any plugins your browser is running.
If you experience any unexpected errors while using either the Tablo Web App or Tablo Subscription portal, make sure you are using one of the browsers above. While other browsers may function and access both of these portals without issue, they have not been optimized and can cause problems.
Comments
