Setting Up Your Legacy Network-Connected Tablo on Roku
Tablo David
Tablo David
The instructions in this article apply to our legacy network-connected Tablo DVRs. For 4th Generation Tablo setup, go here.
This same legacy setup can also be done via Android or iOS.
NOTE - Legacy Tablo apps will no longer be available for download starting September 1st. Many of the underlying technologies used by legacy Tablo apps and services are becoming obsolete and are no longer maintainable. This is why we are discontinuing support for all legacy Tablo apps on September 1st, 2026.
To complete setup of your legacy Tablo via a Roku player*, Roku stick* or Roku-enabled smart TV you must:
  • Connect your Tablo to your home Wi-Fi router via Ethernet.
  • Use the latest version of the Tablo channel/app (minimum version 2.14.0) .
Setup must be done with your Roku connected to a modern television. If your Roku is connected to an older standard definition television, you must use an alternative setup method (see above).
To add the Tablo channel/app on Roku go to: HOME > STREAMING CHANNELS > SEARCH CHANNELS > TABLO TV > ADD CHANNEL > GO TO CHANNEL. Once the app is downloaded, you can begin setting up your Tablo.
1. Ensure You Have What You Need to Complete Setup
You will need an active internet connection, an over-the-air TV antenna and a supported form of recording storage (if your Tablo does not come with onboard storage)
2. Process Firmware Updates If Required
This will ensure your Tablo is running the latest and greatest firmware version.
3. Ensure Your TV Antenna Is Connected
Make sure the coaxial cable is securely attached to the coaxial port on the rear of your Tablo.
4. Select & Confirm Your Location
Location data is used to provide the correct TV Guide Data for your area.
Depending on your location, you'll be asked to enter a ZIP or POSTAL CODE.
5. Give Your Tablo a Name
This will make it easy for you to identify your Tablo, especially if you have multiple Tablo DVRs in your household or are upgrading from a previous model. This can be changed at any time in the future.
6. Ensure You've Connected a Supported Recording Storage Device
If your Tablo does not come with onboard storage, a supported form of recording storage must be connected. For required storage specs and recommendations for your Tablo, visit here.
7. Format Your Recording Storage
Tablo will then format your recording storage for use with Tablo. This will erase all data on the drive, including partitions.
Select the button marked FORMAT to proceed. Its location may be different than shown below.
Formatting a brand new drive should only take a few seconds. Formatting a previously used drive will take a bit longer (between 30-90 seconds depending on the size).
8. Channel Scan
Your Tablo will immediately begin scanning for over-the-air TV channels available in your area.
Recommended channels (those broadcast in HD quality with five green dots indicating excellent signal strength) will be pre-selected with checkmarks.
You may select other channels (those in SD quality) but we do not recommend selecting channels with marginal or poor signal strength (yellow or red dots).
You can also choose to deselect channels that you do not plan to watch like home shopping or foreign language networks at this time.
Are some channels you wish to receive showing marginal reception? You may wish to reposition your antenna and select RESCAN in order to improve signal reception before selecting SAVE & CONTINUE
9. Final Preparations
Once your Tablo has downloaded the first 24 hours of TV Guide Data, it will be ready to enjoy!
While this happens, you may see some handy Tablo tips displayed on the screen.
10. Your Tablo Is Ready
We hope you enjoy your Tablo experience!
If you run into any problems during setup, don't hesitate to touch base directly with our helpful support team
