4th Generation Tablo Technical Specifications
Table of Contents
What's Included
  • Tablo Device
  • Power Supply
  • 4′ Ethernet Cable
  • Quick Start Guide
  • Tablo Apps for Every Device
  • Indoor TV Antenna & 6′ High-Performance RG6 Coaxial Cable (When You Choose the Tablo Total System “2-Tuner / With Antenna" & "4-Tuner / With Antenna”)
Tuners
2 OR 4 ATSC 1.0 Tuners
Ports
  • Power
  • Ethernet 10/100
  • USB 2.0
  • Coax
Dimensions and Weight
  • Height – 35 mm (1.37”)
  • Width – 127 mm (5.00”)
  • Depth – 127 mm (5.00”)
  • Weight – 170 g (5.9 oz)
Audio Format
Pass-Through of 5.1 Surround Sound When Available​
Processing
  • 1 GB RAM
  • 128 GB Flash
Built-In Antenna Amplifier
  • 11dB Gain Per Tuner
  • 75 Ohm Impedance (Input and Output)
  • Can Be Turned Off If Using External Amplifier
Tablo Total System Included Antenna
  • Reception Range – Up to 35 Miles
  • Frequency Range – 87.5-230MHz, 470-862MHz
  • Receiving Range – VHF/UHF
  • Gain – 4-6dB
  • Impedance – 75Ω
Recording Capacity
  • 50+ Hours of Onboard HD Storage
  • Support for USB Hard Drives From 1 - 8TB (~1000 Hours of HD Storage)
Networking
  • 100 Mbps Ethernet
  • 802.11ac Dual Band Wi-Fi With MIMO
Video Format
  • MPEG2 (Recordings Saved to Onboard Storage Will Be Transcoded to MPEG4 to Maximize Capacity)
