4th Generation Tablo WiFi Setup Wizard
Tablo Support - Lauren
The WiFi setup wizard is a tool that will guide you through the process of connecting your Tablo to the internet. We recommend running the WiFi setup wizard on a different smartphone, tablet, or computer than the device you're using to set up your Tablo.
Before you get started, make sure that you have access to your Tablo's MAC address, which is printed on the bottom of the unit. When you have this ready, please click here to navigate to the WiFi setup wizard.
