In general, those in major urban centers in Canada and the United States can expect to receive several free HDTV channels including most major networks.
In the United States, customers in most areas will be able to get FOX, NBC, CBS, ABC, PBS, and CW networks. In Canada, most will be able to get CBC, CTV, Global, CityTV as well as regional and language-specific content. Canadians living close to the border may also be able to obtain signals from American networks.
For a listing of the channels available in your area, visit www.TabloTV.com/channels
The quality of your HDTV reception is based on proximity to HDTV broadcast towers, the type of antenna you’re using and its location (indoor, outdoor, height off the ground, direction).
If you’re receiving less channels than you think you should be, try adjusting the location or direction of your antenna.
For more information on antennas and positioning, please read through our blog series here: http://www.tablotv.com/blog/blog-series-is-over-the-air-ota-hdtv-right-for-you
Comments
