How to Factory Reset your Tablo 4th Gen with Internal Storage
Tablo Support - David
Note: The process outlined in this guide will work for 4th Gen Tablo while using INTERNAL storage.
If your 4th Tablo is using external USB storage or an internal SATA drive, refer to this article.
If you are trying to factory reset your Legacy Tablo, visit this article.
What is a factory reset?
When a factory reset is performed on the Tablo DVR, it is restored to its 'out-of-the-box' state and is essentially running as a new unit. The Tablo DVR's database and all troubleshooting logs will be erased, along with all recordings and recording schedules available on the attached hard drive.
Your Tablo DVR’s current firmware version will be maintained during the factory reset.
You may wish to perform a factory reset on Tablo for one of the following reasons:
  • You are selling your Tablo DVR
  • You are giving your Tablo DVR to a new owner
  • You have tried absolutely everything else to fix your Tablo (including talking to our amazing Tablo Support representatives).
WARNING:
By factory resetting the device, any and all old data accumulated during your usage of the device is erased including information that could be critical for Tablo Support representatives to provide accurate troubleshooting assistance.
Before attempting a factory reset, we recommend trying some of the more basic troubleshooting steps found in this article of the Tablo Knowledge base.
If these steps do not successfully solve your issue, we recommend consulting the Tablo Knowledge BaseTablo Community or Tablo Support team for further assistance.
If you would still like to proceed with a factory reset, the steps are as follows:
WARNING: Proceeding with the factory reset steps below will erase all recordings and recording schedules from your Tablo DVR.
  1. Open the mobile Tablo app on your iOS or Android device. Select the user preferences button on the top right of the application, and then select the 'Sign out' button below your profile. If you are not able to access this screen on the Tablo mobile app, uninstall and then reinstall the app.
  2. Make sure your Tablo's blue LED is solid. Hold down the white reset button on the bottom of the unit for 7+ seconds. The blue LED on the front of the Tablo DVR will begin to flash faster and faster. Once it again turns solid, the Tablo will begin to factory reset. At this point, you can release the white reset button.
  3. Open the Tablo mobile application on your iOS or Android device. Select 'I already have an account' and log in to your original account. From here you will be guided through the rest of the setup process.
