How Do I Tell Which Tablo Model I Have?
Tablo Support - David
There are a couple of different ways you can tell which Tablo unit you have:
Using the Serial Number
You can identify which Tablo you have by the first three letters of the serial number. The serial number can be located on the very bottom of your Tablo unit, as well as the box the Tablo came in.
If the first three letters begin with:
GI-C     This is a DUAL LITE or DUAL 128GB unit.
GI-Q     This is a QUAD or QUAD 1TB unit.
HD-A     This is a DUAL HDMI unit.
HQ-A     This is a QUAD HDMI unit.
LD-B     This is a 2-Tuner*, 4-Tuner* or DUAL 64GB unit*
* These units are no longer available to be purchased
Using the Ports on the Back of the Unit
The ports on the back of your Tablo will help determine if you have a TV-connected Tablo or a network-connected Tablo. It can also help you identify if your network-connected Tablo is a DUAL or QUAD.
Tablo DUAL LITE  or  TABLO DUAL 128GB
The Tablo DUAL LITE and Tablo DUAL 128GB are network-connected units, and will only have ports for the antenna, USB, Ethernet, and power supply.
Tablo QUAD or TABLO QUAD 1TB
The Tablo QUAD and Tablo QUAD 1TB are network-connected units and will have ports for the antenna, USB, Ethernet, and power as well as a SATA compartment for an internal hard drive.
Tablo DUAL HDMI or Tablo QUAD HDMI
The Tablo DUAL HDMI and Tablo QUAD HDMI are TV-connected units and will have ports for power, Ethernet, HDMI, USB, and antenna.
By the Way the Unit Looks
Tablo DUAL LITE or Tablo DUAL 64GB* or Tablo DUAL 128GB
These models are square with rounded corners and air vents on the slightly domed top.
Tablo QUAD or Tablo QUAD 1TB
These models are rectangular with rounded corners and air vents on the slightly domed top.
These models are square with rounded corners, air vents on the slightly domed top, with a shiny half-moon section (the IR remote sensor), and a Tablo logo screen printed on the front. They come with a Tablo-branded remote.
Original Tablo 2-Tuner* and 4-Tuner*
These models are rectangular in shape with a flat top with no air vents. The Tablo logo is screen printed on the front.
