For information on legacy Tablo DVRs and tuners, go here.
The 4th Generation Tablo has either two or four over-the-air (OTA) TV tuners, depending on which model you've chosen.
The primary function of these tuners is to decode the signal coming in from your OTA TV antenna but they also perform other functions.
The 4th Generation Tablo also has either two or four 'virtual' tuners used to stream and record free streaming channels.
Table of Contents
- What a Tuner Is and Is Not For
- Not Picking Up the Same Stations as Your TV or Legacy Tablo?
- Seeing a Tuner Reassigned Error Message?
- Tuner Math Recap
An over-the-air tuner is required for:
- Watching a live OTA antenna TV program.
- Recording an OTA TV program.
An over-the-air tuner is not required for:
- Watching a completed OTA TV recording.
A virtual tuner is required for:
- Watching a live free streaming TV program.
- Recording a free streaming TV program.
A virtual tuner is not required for:
- Watching a completed free streaming TV recording.
This means that the 2-tuner 4th Generation Tablo can support up to two concurrent antenna TV streams or recordings as well as up to two concurrent free TV streams or recordings.
The 4-tuner 4th Generation Tablo can support up to four concurrent antenna TV streams or recordings as well as up to four concurrent free TV streams or recordings.
For example, at the same time across all of the smart TVs, streaming and mobile devices in your home, with a 2-tuner Tablo you can:
- Watch a live OTA antenna TV program in the living room.
- Record a live OTA antenna TV program on another channel.
- Watch a free streaming program in the family room.
- Record a free streaming channel.
OR
- Watch a live OTA TV program in the family room.
- Watch a completed OTA antenna TV recording in the bedroom.
- Record a free streaming program.
- Watch a free streaming program in the kitchen.
Not Picking Up the Same Stations As Your TV or Legacy Tablo?
Over-the-air reception can vary depending on the type of device and the number of tuners being used, as well as the environment and configuration in use. For that reason, it's important to remember OTA signals are based on several factors, and different types of devices can have different results. This is usually resolved by optimizing the OTA reception for the device you're primarily using.
The 4th Generation Tablo also has an optional in-line antenna amplifier. If you are already using an amplified antenna or live very close to your local broadcast towers, you may wish to disable this setting to avoid overloading your Tablo's tuner, leading to potential signal loss.
Recordings take precedence over live TV streams, so your live TV session may end if a tuner is needed for a recording. You can, however, unschedule the recording in question and return to watching live TV if you prefer.
Tuner Math Recap
| Tablo Actions | Requires Tuners? YES / NO |
2-Tuner Max Concurrent Actions | 4-Tuner Max Concurrent Actions |
| Watching live OTA antenna TV | YES | 2 live streams | 4 live streams |
| Recording OTA antenna TV | YES | 2 in-progress recordings | 4 in-progress recordings |
| Watching a completed OTA antenna recording | NO | Up to 6* | Up to 6* |
| Watching a live free streaming channel | YES | 2 live streams | 4 live streams |
| Recording a free streaming channel | YES | 2 in-progress recordings | 4 in-progress recordings |
| Watching a completed free streaming recording | NO |
Up to 6* |
Up to 6* |
*Depending on the quality of your home Wi-Fi network.
