VHF vs. UHF TV Antenna Frequencies
Tablo David
Tablo David
Over-the-Air (OTA) TV signals are distributed across two different frequency bands: UHF (Ultra High Frequency) and VHF (Very High Frequency).
While most OTA TV antennas on the market are designed to capture both frequencies, some antennas – especially certain indoor antennas – are optimized primarily to capture UHF channels.
If you’re having trouble receiving one or two channels even though you’re close to your local broadcast towers, it may be because your antenna is not designed to pick up VHF frequencies.
Table of Contents
What are VHF and UHF TV Frequencies?
In the US, the VHF television band occupies frequencies between 54 and 216 MHz, and the UHF band between 470 and 608 MHz.
In general, VHF channels are numbered 2 to 13, and UHF channels are numbered 14 to 36.
However, the channel’s physical broadcast frequency is not always reflected by the channel number you see.
For example, channel 6 in Richmond, VA has a virtual channel (i.e., channel number) of 6 on your TV or Tablo DVR but is broadcast on a transmit channel of 25.
While it is possible for stations broadcasting in the VHF band to have a virtual channel number in the UHF channel range (14+), this is rare.
How Can I Tell If I Need a TV Antenna That Supports Both UHF & VHF?
As mentioned above, OTA TV channels between 2 and 13 are often broadcast on the VHF band, so it’s best to start by reviewing your local channel lineup to find out which channels are broadcasting your favorite networks like ABC, CBS, FOX, NBC and the CW.
For example, in Dallas, viewers might believe they could miss out on popular networks like FOX (KDFW), which is channel 4, and ABC (WFAA), which is channel 8, when using a UHF-only TV antenna.
However, just because a channel has a virtual or advertised channel number lower than 14 doesn’t necessarily mean it’s broadcast on a VHF frequency.
The best place to confirm the TV channel’s frequency is via the FCC’s website at: https://www.fcc.gov/media/television/tv-query.
You can search for station information by city or by call sign.
As you can see, FOX affiliate KDFW’s virtual channel is 4, but its transmit channel is 35, so you won’t need a VHF-capable TV antenna to receive it.
However, ABC affiliate WFAA has both a virtual and a transmit channel of 8, which is indeed on the VHF band, so you would need a VHF-capable TV antenna to receive it.
OTA TV Antenna Shopping Tips
If you want to access TV channels available in both VHF and UHF frequencies in your area, inspect the features list on the packaging or online listing of the TV antennas you’re considering, to ensure they include support for both UHF and VHF bands.
Very few flat indoor antennas like the one below support VHF signals.
If there’s already a TV antenna mounted on your roof and you’re not sure what brand or style it is, antennas with VHF capability generally have long prongs and are quite large, whereas UHF-only antennas are slightly smaller and have shorter prongs or loops.
Most outdoor antennas will have both long and short prongs, or prongs and loops, and therefore will support both frequencies. However, TV fans with channels in the VHF low spectrum (2-6) may need an even more specialized antenna with very long prongs to receive those stations.
