This article covers factory resetting specific legacy Tablo DVRs. For instructions on how to factory reset a 4th Generation Tablo DVR, go here.
The process outlined in this guide will work for Tablo DUAL LITE, Tablo DUAL 64GB or Tablo DUAL 128GB while using internal storage.
If your Tablo is using external USB storage or an internal SATA drive, refer to this article. If you are trying to factory reset your Tablo HDMI, use this article.
What is a Factory Reset?
When a factory reset is performed on the Tablo DVR, it is restored to its out-of-the-box state and essentially runs as a new unit. The Tablo DVR's database and all troubleshooting logs will be erased, along with all recordings and recording schedules available on the internal hard drive.
Your Tablo DVR’s current firmware version will be maintained during the factory reset.
You may wish to perform a factory reset on a Tablo for one of the following reasons:
- You are selling your Tablo DVR.
- You are giving your Tablo DVR to a new owner.
- You have tried absolutely everything else to fix your Tablo (including talking to our amazing Tablo Support representatives).
WARNING
A factory reset should not be attempted as a casual troubleshooting step and should only be done as a last resort by someone who knows what they’re doing.
By factory resetting the device, any and all old data accumulated during your usage of the device is erased, including information that could be critical for Tablo Support representatives to provide accurate troubleshooting assistance.
Before attempting a factory reset, we recommend trying some of the more basic troubleshooting steps found in this article of the Tablo Knowledge Base.
If these steps do not solve your issue, we recommend consulting the Tablo Knowledge Base, Tablo Community or the Tablo Support team for further assistance.
If you would still like to proceed with a factory reset, the steps are as follows:
How to Factory Rest
WARNING: Proceeding with the factory reset steps below will erase all recordings and recording schedules from your Tablo DVR.
- Make sure your Tablo's blue LED is solid. Hold down the blue reset button on the back of the unit for 7+ seconds. The blue LED on the front of the Tablo DVR will begin to pulse faster and faster. Once it again turns solid, the Tablo will begin to factory reset. At this point, you can release the blue reset button.
- Using Firefox or Safari, head over to http://my.tablotv.com/ (or any of the Tablo mobile apps on smartphones and tablets). On the main Connect to Tablo page, a red X should be visible. Select the red X and confirm that you want to delete the Tablo from that device. Then select Rescan and Connect to the Tablo below the New Tablo header.
- You will be guided through the setup process. This includes entering your zip/postal code and running a channel scan.
