Connecting Tablo to Wi-Fi with Android
Once you have taken your Tablo out of the box and you have attached the power, antenna and hard drive, you are ready to set up Tablo via Wi-Fi.
Begin by downloading the Tablo app from the Google Play Store, then open the Tablo app on your iPad.
When you open the Tablo app, you will be taken to the main ‘Add a new Tablo’ screen.
Select 'Add via Wi-Fi'.
Tap 'Continue' on the prompt that appears.
The next screen will instruct you to connect to your Tablo’s network.
To do this, exit from the Tablo app and navigate to the Settings screen.
Select Wi-Fi under the settings menu. Your Tablo will appear in the Wi-Fi list. To connect to your the Tablo's WiFi network, select it from the list.
Once you have connected to your Tablo’s Wi-Fi network, return to the Tablo app.
It will prompt you to select your home network and enter the password.
Once you have typed in your password, select 'Join'.
 From here, you can begin formatting your hard drive, scanning for channels, and using your Tablo!
Was this article helpful?
0 out of 0 found this helpful
Comments
Powered by Zendesk
