Setting up Tablo ENGINE - Part 1: Permissions
Welcome to the Tablo ENGINE Setup Guide. This guide will help you navigate through the initial Tablo ENGINE Setup. If you haven't attached your tuner and (optional) hard drive to your NVIDIA SHIELD yet, follow our quick start guide to get yourself hooked up!
The first few steps of the Tablo ENGINE's setup process will be allowing permissions in order to turn your NVIDIA SHIELD into an OTA DVR.
First, the Tablo ENGINE app will ask to allow permission for the USB tuner.
Next, the Tablo ENGINE app will guide you through the format process for your attached USB storage.
The Tablo ENGINE app will guide you through formatting your hard drive and setting it up as default storage.
Finally, the Tablo ENGINE app will show you how to move all necessary app data to your external storage. This allows the Tablo ENGINE to store your scheduled shows and recordings properly.
Next, you will need to change the Tablo ENGINE app's default storage option.
Once this has been completed, the Tablo ENGINE app will start up. Follow our next guide to complete the setup.
Was this article helpful?
0 out of 0 found this helpful
Comments
Powered by Zendesk
