Adding Missing Guide Data
Once your Tablo has run its channel scan, the Live TV guide will show 24 hours of guide data. The remaining 2 weeks are sorted into the TV shows, Movies and Sports tabs.
If your Tablo is missing guide data, we can have it added for you from our end! Since OTA guide data is organized through our guide data provider by zip/postal code, it’s possible that some new channels may not yet have their schedules loaded.
Identifying missing guide data is easy. Just check your live TV screen. If the rows in the live TV screen for specific channels are blank, your Tablo is most likely missing the guide data for these channels. Just send our support team a note at https://bit.ly/TabloTVHelp, or give us a call at 1-844-TABLOTV (822-5688). We’ll create a case for you and have it added ASAP.
Was this article helpful?
0 out of 0 found this helpful
Comments
Powered by Zendesk
