Setting up your new Tablo
For a full video walkthrough of the unboxing process, check out the link below:
http://support.tablotv.com/hc/en-us/articles/115001797366-Unboxing-and-Setting-up-your-Tablo-DVR
Antenna Setup
One of the first steps in getting free Over-the-Air TV is finding an antenna. Today’s digital HDTV Over-the-Air (OTA) antennas are not like the rabbit ears of old so keep your tinfoil for wrapping last night’s leftovers. Modern antennas deliver perfectly crisp picture quality in full HD and come in a variety of form factors and prices.
Antenna Style Options
HDTV antennas cost approximately $20 to $200 and come in several different form factors:
•Flat antennas – Are placed indoors, usually affixed to windows or walls
•Table-top antennas – Are small and placed indoors on a flat surface
•Attic mount antennas – Are mounted within your home’s attic
•Roof mount/outdoor antennas – Are mounted on the outside of your home, either on the roof or another structure like a pole or tower
To find out more about which antenna is right for you, check out our blog:
https://www.tablotv.com/blog/tablo-ota-hdtv-antenna-buyers-guide/
Once you’ve picked out your antenna, make sure it’s placed ideally. The quality of your Over-The-Air HDTV signal reception is highly dependent the placement of your antenna. The ideal location for yours within your home may be on the roof, your garage, your attic, a bedroom window or a myriad of other places. The key factors here are heigh, direction and obstructions.
Check out our blog post for full details on how you can best set up your antenna:
https://www.tablotv.com/blog/position-matters-hdtv-antenna-placement/
Adding your Tablo to your Network
The Tablo can be added to your network using either Wi-Fi or Ethernet. To add the Tablo to your network using an Ethernet cord, simply attach the Ethernet cord to the back of your Tablo, and the other end to your router. Then attach the A/C adaptor to the back of your Tablo. Wait for the blue LED on the front of the Tablo to stop blinking, and you’re done! You can proceed with the rest of the setup.
If you intend to use your Tablo on Wi-Fi, use the link below to choose the platform you’d like to do the setup with: http://support.tablotv.com/hc/en-us/sections/200278929-Getting-Connected-to-Tablo
Hard Drives
Now it’s time to attach a hard drive. We’ve got a list of recommendations you can view here:
https://www.tablotv.com/blog/tablo-usb-hard-drive-specifications-suggestions/
In short, just about any USB 2.0 or 3.0 disk from 250GB to 8TB will work. Both powered and portable drives are compatible. Depending on the recording quality your Tablo is using, and the size of drive you select, here’s a chart detailing how many hours of OTA TV you can expect your hard drive to store:
 Recording Quality
HD 1080
(720@60fps)
HD 1080
HD 720
 HD 720
SD 480
Bandwidth
10 Mbps
8 Mbps
5 Mbps
3 Mbps
2 Mbps
Gigabytes/Hour
4.6 GB/hr
3.7 GB/hr
2.4 GB/hr
1.5 GB/hr
1 GB/hr
Next up, channel scans.
Troubleshooting
If you’re having any issues with your Tablo, don’t hesitate to check out our troubleshooting guide linked below. This article covers a large majority of minor issues, and gives you quick and concise solutions to solve whatever problem you’re running into:
http://support.tablotv.com/hc/en-us/articles/208223573-Troubleshooting-your-Tablo
Of course, don’t hesitate to reach out to our support team if you’d prefer to chat! You can reach us by email here: https://bit.ly/TabloTVHelp or by phone at 1-844-TABLOTV (822-5688) between 9:30AM to 5:30PM, Monday to Friday.
Was this article helpful?
0 out of 0 found this helpful
Comments
Powered by Zendesk
